1994 Chevy S-10 ABS
BOB STRASEN
  • 1994 CHEVROLET S-10
  • 6 CYL
  • MANUAL
  • 157,000 MILES
Abs light comes on even after I replaced speed sensor like repair manual says, brakes good, tires good
Saturday, August 16th, 2008 AT 1:58 PM
JETSA
  • 117 POSTS
What was the code you get and which sensor did you replace?
Sunday, August 17th, 2008 AT 10:41 AM
BOB STRASEN
  • 8 POSTS
I asked at the parts store about this issue and then I read in the s 10 repair manual to replace the speed sensor which is at the rear housing, my brakes are good tires good. Bob
Monday, August 18th, 2008 AT 2:39 PM
JETSA
  • 117 POSTS
I have seen this a few times. When you remove the speed sensor from the transmission, 1st off check the shape of the plastic gear on the end of the sensor. If it is concaved, smaller or larger on the ends than in the middle, you will also need to replace the gear inside of the transmission that turns the speedo sensor. Another thing to check is while you have the speed sensor out, try moving the gear that is inside the transmission (in the hole where the speedo sensor just came out of). If that gear moves, your going to have to take off the end of the transmission and see why the gear isnt being held in place.
Monday, August 18th, 2008 AT 6:56 PM
BOB STRASEN
  • 8 POSTS
When I removed the speed sensor, I felt around the inside of it it felt like regular gears with teeth and no it did not move when I tried to move it with my finger Any suggesstions. The new sensor I put in I heard it click like it set in to place
Tuesday, August 19th, 2008 AT 2:58 PM
JETSA
  • 117 POSTS
Well back in the day, there used to be a problem with the ABS modules that would cause various ABS codes that we could never figure out. Finally found out that by trying a test module, the problem went away so we assumed it was a glitch in the module. If this model has a black plastic box mounted next to the master cylinder with 2 connectors going into it, then possibly that might be whats happening. Other than that guess, you might try ohming the wiring from the ABS module to the sensor, but I'm thinking that the wires from the sensor go somewhere else before going to the module.
Something like this, it might be wise to get a shop involved or it could get costly with guesswork.
Tuesday, August 19th, 2008 AT 9:43 PM
