2001 Chevy S-10 abs
2001 CHEVROLET S-10
62,000 MILES • 6 CYL • 2WD • AUTOMATIC
VIC MILLER
why does my abs light and parking break light come on together. Thanks Vic
Jul 2, 2008 at 4:07 AM
SWILLIAMS
  • 597 POSTS
Check for a leaking brake line or caliper or wheel cylinder. The brake light come on to tell you there is a mechanical fault in the system. The ABS light is on because of the failure as well. You will need to repair the leak and bleed the brake system.
Jul 5, 2008 at 4:29 AM
