You have two options. You can buy some flurecent dye and a blacklight used for testing it and put the dye in the oil and run the vehicle then use blacklight and look for leak. Or you can take a pressure washer. Clean all the old oil off and spray baby powder on it and run it. Youll see where the leak is coming from on the baby powder right away
SPONSORED LINKS
Friday, June 4th, 2010 AT 7:00 PM
