1997 Chevy S-10
SINJUN
  • 1997 CHEVROLET S-10
  • 4 CYL
  • 99,987 MILES
A/C not working
The compressor will not engage.
The system holds some pressure.
I can get about 1/2 a pound of freon in
I have replaced the A/C Compressor #14/ 10 amp fuse
( it was NOT blown)
Are there any other fuses in the system? Or relays?
Low pressure switch has 3 wires/ when I jumped that plug the engine died (oops) it did restart.
Not sure what to do
Wednesday, March 24th, 2010 AT 8:02 AM
TOOOMANYTOYS
  • 513 POSTS
Check the a/c relay located under hood in fuse block swap with another relay to see if that works. If not try jumping relay with a fused jumper at terminal 30 and 87. If compressor comes on and blows cold it is most likely electrical issue. If its not cold you may have a pressure issue.
Wednesday, March 24th, 2010 AT 8:15 AM
