1996 Chevy S-10 Fuel Pump
TGREASEWOOD
  • 1996 CHEVROLET S-10
1996 Chevy S-10 Two Wheel Drive Automatic
Is there a reset switch for a fuel pump in a 1996 chevy s-10 pickup engine 2.2? I've replaced the fuel pump and reconnected everything and will not start.
Monday, November 1st, 2010 AT 10:06 AM
JDL
  • 16,098 POSTS
No reset switch. There is a fuel relay and an oil pressure switch in the fuel pump circuit, wired in parallel to the pump. They both get voltage from ecm bat fuse.
Monday, November 1st, 2010 AT 10:10 AM
Check the fuel pressure if its within specs and also check for spark
