Monday, January 18th, 2010 AT 6:56 PM
I had a bad fuel pump. I repacedit. But it still will not start. Checked for power to the pump did not have power only if I moved the key I repaced Ignition switch. Now have power but will not start. I can jump the pump with a battery charger and I can then start the truck. I had checked the fuse and the relay befor I did all that. What more can I check?
