1996 Chevy S-10 Battery light
BKR1986
  • 1996 CHEVROLET S-10
  • 6 CYL
  • 130,000 MILES
Hello my battery light is on and reading 11 volts
Charge. I had the alternator tested and they said it was fine but my battery was bad so I changed it and nothing changed. Now it seems like im losing power when I press the petal down it seems like im just feathering it, It doesnt rev up. And the interior lights are dimmer than they used to be, do you have any ideas? Thanks for your help
Wednesday, April 29th, 2009 AT 3:51 AM
DOCFIXIT
  • 18,828 POSTS
Maybe a bad ground cable. Check at battery pull the insulation back those side posts are easy to hide corrison. Wire brush and clean with a solution of backing soda and water
Wednesday, April 29th, 2009 AT 10:47 AM
