electrical problem
273,000 MILES • 2.2L • 4 CYL • 2WD • MANUAL
CWB4LIFE12
All started when the tensioner for timting chain broke. Fixed that problem, 5 bent valves, fixed, new crank, cam, oil pressure, sensors. running like a top and then all of the sudden ecm/ ign fuse blows as soon as I try to start. And battery light stays on but battery has been tested and is good, 12.5-13.5 volts.Try to find as many chaffed wires I could, thought I had it fixed, because fuse didn't blow , but now I have no spark.
Mar 24, 2016 at 7:44 AM
HMAC300
  • 48,601 POSTS
try resetting your security system or use another key if another key doesn't work you'll have to h ave it scanned for a security issure. A new key will not work until car is started then you can program it as stated in your manual
Mar 24, 2016 at 9:48 AM
CWB4LIFE12
the key cylinder was replaced about a year ago, could it be the key still?
Mar 24, 2016 at 10:40 AM
HMAC300
  • 48,601 POSTS
well it may be if you have another key try that then scan for codes might be something else.
Mar 24, 2016 at 10:46 AM
