1996 Chevy S-10
IRONKING
  • 1996 CHEVROLET S-10
Engine Mechanical problem
1996 Chevy S-10 4 cyl Two Wheel Drive Manual
it starts and runs fine but when it heats up it starts cutting out when you push the throttle but still idles fine. It has a new fuel pump, fuel filter, pressure regulater, and clean injecters. What would my problem be. Thanks, larry
Monday, September 7th, 2009 AT 10:04 AM
JOERIN42
  • 8 POSTS
After reading your question, and remembering a similar issue with my previous S-10, 2.8, it could be a dirty or cracked distributor and/or rotor. Try this. After dark, with headlights off, start the engine, open the hood and listen for and look for open spark. Alot of times a broken or cracked spark plug wire/end can cause weak ignition, thus lack of power.
Sunday, September 13th, 2009 AT 9:25 PM
