1995 Chevy S-10 overheating
GRAHAM24510
  • 1995 CHEVROLET S-10
Engine Cooling problem
1995 Chevy S-10 4 cyl Two Wheel Drive Manual 150k + miles
I have a 95 chevy s10 in which I just put a new engine in (used) it seems to run great until after after about 15 minutes of driving then it runs hot I put a new thermostat in which I checked and is working properly, checked the waterpump working good also, flushed and back flushed the system, there are no coolant leaks any where what am I over looking?
Sunday, August 24th, 2008 AT 12:01 PM
RKING
How old is your radiator? After warming up stick your hand through the front grill and feel on the radiator too see if the entire surface is hot and not clogged. Check for collasping rad hoses. Check the exaust for good flow and the catalytic converter.
Wednesday, September 3rd, 2008 AT 9:29 PM
