1995 Chevy S-10 brake booster
14,000 MILES • 6 CYL • 4WD • MANUAL
MIKE DIGRAZIA
how do you install a used brake booster and make sure that it is working properly?
Oct 5, 2010 at 10:17 AM
SATURNTECH9
  • 30,869 POSTS
1. Disconnect master cylinder assembly and vacuum hose from power brake unit.
2. Disconnect power brake unit pushrod from brake pedal.
3. Remove power brake unit attaching nuts from inside of vehicle.
4. Remove power brake unit.
5. Reverse procedure to install. Torque power brake unit and master cylinder mounting nuts to specification.
The main way to test a used one is to take a hand vacuum pump and put the brake booster under vacuum and see if it hold's vacuum.
Oct 5, 2010 at 10:27 AM
