1994 Chevy S-10 wont start
BUBBA8188
  • 1994 CHEVROLET S-10
  • 6 CYL
  • 4WD
  • 194,000 MILES
I have a 94 chevy s10 and it wont start the starter is fine and it will turn over if I spray starter fluid into the carb but only for a few seconds before it dies could there be any other solution besides replacing the fuel pump?
Wednesday, October 27th, 2010 AT 5:05 PM
HMAC300
  • 48,601 POSTS
Check your fuel pressure it should be 9-11 lbs. If it isn't hen you'llneed to change the pump and fuel filter. You might chekc it after just a filter change but it sounds as if your pmp may be bad.
Thursday, October 28th, 2010 AT 7:21 PM
