1994 Chevy S-10 wont start
HOGMOLLY
  • 1994 CHEVROLET S-10
  • 6 CYL
  • 4WD
  • 164,000 MILES
I had a computer scan said oxigen sensor bad and fuel pressure regulater replaced now wont start
Thursday, December 4th, 2008 AT 9:50 AM
JDL
  • 16,098 POSTS
If your saying it cranks good, but won't start. Did you ever chek fuel pressure?
Do you have TBI or spider type fuel system?
Thursday, December 4th, 2008 AT 10:44 AM
HOGMOLLY
Yes checked pressure have spider tipe
Thursday, December 4th, 2008 AT 2:44 PM
JDL
  • 16,098 POSTS
What was the fuel pressure reading? Those spider systems are noted for problems.
KOEO fuel pressure should be 58 psi or above, or it may not start.
Thursday, December 4th, 2008 AT 3:41 PM
HOGMOLLY
It was 65psi how can u tell if spider is bad?
Saturday, December 6th, 2008 AT 9:01 AM
JDL
  • 16,098 POSTS
If you retrieved trouble codes, what were they? The codes won't tell you what to replace, just that there is a possible problem on that system.
Did you check for spark at the plugs, with the engine cranking? Are you saying the engine ran ok before you worked on it?
Your fuel pressure looks ok. Did you try spraying starter fluid past the throttle-valve? Does the engine try to start? There can be safety issues using a flammable spray, that is your responsibility.
Wednesday, December 10th, 2008 AT 3:13 PM
HOGMOLLY
The codes wer 23 and 45 I got it started but runs real rough now
Wednesday, December 10th, 2008 AT 6:05 PM
JDL
  • 16,098 POSTS
The code 23 has to do with the inlet air temp sensor. You can do a resistance test on that sensor, see if the resistance changes at different temps.
The code 45 is o2 sensor rich, I'd look at the iat sensor and circuit, first.
Thursday, December 11th, 2008 AT 9:40 AM
