1994 Chevy S-10 Timing Chain
JETRINGE
  • 1994 CHEVROLET S-10
  • 6 CYL
  • MANUAL
  • 16,000 MILES
Running perfect until this morning 3 miles into commute, heard loud knock and now runs as if on 3 or 4 cylinders and a new tapping from one of the valves. Sound's like timing jumped? In addition to replacing chain and gears - anything else to be concerned with? Thanks.
Monday, December 28th, 2009 AT 11:24 AM
  • 109,772 POSTS
Before replacing the timing chain, check it to make sure it jumped time. THere may be internal damage to the engine.
LEt me know what you find.
Saturday, January 2nd, 2010 AT 6:26 PM
JETRINGE
Timing was definitely an issue. Replaced slacked old chain, all plugs, wires, cap and rotor. Now runs rough and timing mark jumps back and forth 2-4 degrees or more. Distributor seemed ok - not worn but maybe damaged and maybe a lifter is bent? Not sure at this point.
Monday, January 4th, 2010 AT 10:23 AM
  • 109,772 POSTS
Is there any noise coming from the engine? Also, are there any vacuum leaks? When off idle, does it smooth out?
Monday, January 4th, 2010 AT 11:16 AM
