A fuel pressure regulator should control the fuel pressure. IF the the pressure is in spec. And it is critical, then I would start looking at ignition.
CFI failures wash carbon out of intake. Goes straight to EGR valve and hangs it open. I remove and clean them as part of a CFI repair. EGRs commoning up are common on the 4.3.
What is the cap and rotor like?
Is there any play in the distributor shaft? Seen bad distributors on these.
SPONSORED LINKS
Monday, February 8th, 2010 AT 5:36 AM
