Originally I just had a radiator fluid leak from a hose, and I already fixed that, but now I also noticed another leak which is spewing out of the muffler
the truck broke down while I was driving
and it will no longer start- although the engine is not seized, it will turn over it just doesn't fire
tonight I'm going to remove the radiator and also the muffler to see whats going on, I also plan on changing the distributor cap tomorrow
when I checked the oil level after trying to start up the car I noticed it was empty. I added oil and some water to the radiator, and it no longer runs, this may also be due to the first leak out of the hose which was spraying fluid all over the distributor cap, I already went to a junk yard to get an estimate a new engine and they told me 500 dollars plus tax- I was wondering would be a cheaper way to fix my problem?
SPONSORED LINKS
Wednesday, March 5th, 2008 AT 2:58 PM
