1994 Chevy S-10 Chevy S-10
ALLEN4349
  • 1994 CHEVROLET S-10
Electrical problem
1994 Chevy S-10 4 cyl Two Wheel Drive Manual
94 s-10 2.2L. There is a short somewhere and when you turn the key over the engine light clicks and flickers and all accessories, headlights, radio won't work at all, but, you can turn the steering wheel left or right and the short goes away, and when I try to start the truck, the black wire from the steering harness (under the steering column), which grounds itself, catches fire and melts. Thank you.
Wednesday, December 9th, 2009 AT 9:20 PM
MERLIN2021
  • 17,250 POSTS
Take the steering column covers off and see if any wires are getting caught in the turning parts of the column. ANY wire catching fire, needs to be isolated! Tape it up!
Thursday, December 10th, 2009 AT 2:48 PM
ALLEN4349
Could it be the ignition switch gone bad? There seems to be no wires being caught and everything looks alright.
Thursday, December 10th, 2009 AT 7:03 PM
MERLIN2021
  • 17,250 POSTS
Yes it could, but didnt you say a wire was burning?
Friday, December 11th, 2009 AT 2:11 PM
ALLEN4349
Yes sir. I found out that that harness is for the turn signals. The black wire from the bundle that is feeding that harness is the one burning up, along with the one off of the turn signal side that is grounded to the metal on the steering column.
Friday, December 11th, 2009 AT 5:22 PM
MERLIN2021
  • 17,250 POSTS
Ususally the black wires are grounds, unless they have a stripe! So this would men a power wire is chaffing with the ground wire and shorting out, unplug the Mutifuntion switch(turn signal) and see if it stops burning, you may need to replace that switch.
Sunday, December 13th, 2009 AT 8:39 AM
