1994 Chevy S-10
YOJOMAMA
  • 1994 CHEVROLET S-10
Engine Mechanical problem
1994 Chevy S-10 6 cyl Two Wheel Drive Automatic
i submitted a question about 8 days ago, I can't afford a donation, however on my original question, I forgot to mention this vehicle is a chevy s10 blazer, not a s10 pick-up. I'm not sure if this makes alot of difference or not
Tuesday, December 22nd, 2009 AT 4:35 PM
Basic stuffs below do it and see what happens
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Tuesday, December 22nd, 2009 AT 4:39 PM
