Since it push started, I take it you mean it wont crank hot. Sounds like the starter is bad, common for them to not work when hot. Check for 12 volts at the small wire on the starter with key in crank position. If it has power then the starter needs to be replaced. If none, then get back to me and we will figure out where it stops
SPONSORED LINKS
Wednesday, February 13th, 2008 AT 7:40 AM
