1993 Chevy S-10 Transmission
BLAZEROWNER
  • 10 POSTS
Transmission problem
1993 Chevy S-10 6 cyl Four Wheel Drive Automatic
can't get trans. pan back in plz help
Jan 13, 2009 at 5:13 AM
DE772601
  • 123 POSTS
Hello well to try to help you out i know the cross member is not in the way but if you can tilt the pan up by the y pipe in the front and then slide it into place that usually how i do this, it should go right into place. I hope this will help you get the job done.
Jan 13, 2009 at 12:00 PM
BLAZEROWNER
  • 10 POSTS
Thanks for your reply but what I did was raise the trans. a little then jack up on the front left side ( like changing a tire) that gave me enough clearence. hope this helps someone in the furture
Jan 15, 2009 at 12:23 AM
DE772601
  • 123 POSTS
Hi well im glad i could help, any way if any problems in the future happen hope i can answer them .
Jan 15, 2009 at 1:09 PM
