I have a 4.3l V6 with approximately 212000. I think I have jumped the timing chain, because of rough starting and the inability to keep it running after the initial start. I have ran a compression test and have the PSI reading for the cylinders. 1 - 170, 2 - 170, 3 - 160, 4 - 175, 5 - 180, 6 - 170
My repair manual from haynes says that it should only beno greater than 100 psi. Am I missing something here? The truck I have does not have A/C is an automatic with overdrive (700r4).
SPONSORED LINKS
Thursday, March 4th, 2010 AT 11:23 PM
