1992 Chevy S-10 Fuel problems
FIREBIRDFORMULA350
  • 1992 CHEVROLET S-10
  • 4 CYL
  • MANUAL
  • 176,000 MILES
My 1992 S-10 tahoe and it acts like its not getting fuel even though I have a new pump on it, and plugs and wires. I'm thinking injector. Any ideas?
Thursday, September 2nd, 2010 AT 7:55 PM
JDL
  • 16,098 POSTS
Did you visually check for spark at the plugs, engine cranking? Use a gage and check fuel pressure. Some of the national brand autostores used to loan out a fuel pressure gage. Are there any applicable mil codes? Engine cranking, can you see an injector spray pattern? Use a noid lite, check for injector pulse. The voltage to the injector probably goes hot with the key on, any voltage. The ground for the injector should be controlled by the pcm.
Friday, September 3rd, 2010 AT 9:56 AM
