1993 Chevy S-10 fuel trouble
178,000 MILES • 6 CYL • 4WD • AUTOMATIC
BEEFERMAN1
hey i have a 1993 s-10 blazer with the v-6 vortec motor with cpi injection at first i had raw gas in #3 cylender and now i have a crankcaes fule of gas is this from a bad injector or is there some thing i dont know about thanks for your time jim
Feb 8, 2009 at 9:11 AM
2CARPRO JACK
  • 11,533 POSTS
Those injectors stick all of the time.Either shut or open. The updated injectors have only 1 valve instead of 2 and does away with most of the issues, the fuel pressure regulators blow out alot as well, they are mounted on the side of the injector. They also have problems with the feed lines under the upper intake leaking. You will probably have to take the upper intake off to see what is going on
Feb 8, 2009 at 11:46 PM
BEEFERMAN1
i just got it home and took it apart both inlet and outlet fuel lines aer split under the air horn thanks for time 2carpro guys jim
Feb 9, 2009 at 10:08 AM
2CARPRO JACK
  • 11,533 POSTS
Good find.
Feb 9, 2009 at 11:23 AM
