1991 Chevy S-10 No fuel at injectors for start.
1991 CHEVROLET S-10
170,000 MILES • 6 CYL • 2WD • AUTOMATIC
CELIFF
  • 7 POSTS
91 S-10 won't start, good spark, no fuel from injectors. Fuel pump comes on when key is turned. Will start and run with fuel sprayed in throttle body while startng. While running there is good fuel from injectors, just no fuel for starting??
Mar 8, 2010 at 7:18 PM
  • CERTIFIED EXPERT
  • 110,176 POSTS
When you turn the key to the run position, do you hear the pump come on? Have you checked the relay?
Mar 8, 2010 at 11:50 PM
CELIFF
  • 7 POSTS
Yes the pump spins up for a couple seconds. gauge reads 12 psi, manual says 9-13 psi.
Mar 9, 2010 at 6:33 PM
  • CERTIFIED EXPERT
  • 110,176 POSTS
Are you getting power to the injector when the key is in the start position?
Mar 9, 2010 at 10:12 PM
CELIFF
  • 7 POSTS
11.8 volts on both red and white wires
Mar 10, 2010 at 6:19 PM
  • CERTIFIED EXPERT
  • 110,176 POSTS
If you are getting power to the injector in the start position and fuel pressure to it, the only thing I can say is the injector must be bad. Just no fuel for starting??
Inspect. and test the fuel pump relay and the fuel pump/oil pressure sending unit.
The fuel pump relay primes the system for 2secs, when engine start cranking and oil pressure goes over 4psi the fuel pump and oil pressure sending unit powers the fuel pump at all times.
Mar 11, 2010 at 10:00 PM
CELIFF
  • 7 POSTS
And if I start it with a spray of fuel or starter fluid it runs and the injectors spray fuel in the trottle body. They just won't spray while starting?? What would cause that?? I can hear the pump spin up for 2 secs when the key is turned. I did the fuel pump relay check from the Haynes manual; "Idle at normal operating temp, disconnect the fuel pump relay. If the engine stops the oil pressure switch is faulty." When I disconnect the relay the engine continues to run. Oil pressure reads 40 psi while trying to start and 10-15 running at operating temp.
Mar 11, 2010 at 11:42 PM
  • CERTIFIED EXPERT
  • 110,176 POSTS
The only thing I can say is the injector itself or the PCM. Inspect and test the coolant temperature sensor-
Here's the catch:. Will start and run with fuel sprayed in throttle body while starting. While running there is good fuel from injectors
If there's a problem with the computer ground drivers I don't think it will continue to run after you prime it-
Sounds like the computer ground drivers for the injectors is defective or no ignition reference signals being receive by the computer and not synchronizing the injectors
Mar 12, 2010 at 7:48 AM
CELIFF
  • 7 POSTS
Swapped out ECM, no change still won't start. Starts after manually spraying fuel in the throttle body. Runs for 5 minutes then dies... Temp sensor looks good, cleaned, measures 3.4 ohms?? Is that ok?? can't find reference for it. Pressure gauge reads 12 psi, manual says 9-13 psi Yep 3,400 ohms, on a cold engine. It was a auto-ranging meter, I read it wrong. If the temp senor is good what else could it be??
Mar 24, 2010 at 7:42 PM
CELIFF
  • 7 POSTS
Anything else???
Mar 29, 2010 at 4:16 AM
CELIFF
  • 7 POSTS
Replaced distributor, module, and rotor... Starts and runs great. Thanks for not replying for the last 2 weeks as well!!!
Apr 8, 2010 at 11:26 PM
