Engine won't start. Fires with starting fluid. Fuel pump working. Pressure past fuel filter and all the way to engine fuel rail. What do I check next?
Monday, September 28th, 2009 AT 2:41 PM
JDL
MECHANIC
Welcome to the forum, What is the litre size of engine? Are you TBI fuel injection? Can you see injector spray pattern, engine cranking? Use a noid lite, check for injector pulse, cranking.
SPONSORED LINKS
Monday, September 28th, 2009 AT 2:47 PM
OAKLANDS
MEMBER
Yes it's TBI. Where do I check for spray?
Monday, September 28th, 2009 AT 3:26 PM
JDL
MECHANIC
If the air filter housing fits on top of the throttle-body, remove the housing, you should be able to see injectors, watch the bottom of injector/s, engine cranking, for spray. What is the litre size of engine?
