1992 Chevy S-10 engine hard starting
MIDNIGHT_06MAN
  • 1992 CHEVROLET S-10
  • 4 CYL
  • 212,354 MILES
I have a 1987 chevy s10 with a 1992 engine it is hard to start when cold it seems the engine runs on 2 cyclinders for about 2 min then kicks over to 4 cylinders. Then after that the engine high idles does not kick down after it is warmed up.I replaced wires plugs. Fuel filter air cleaner. And as of yesterday I got a clicking noise in the rear of the truck sounds like rocks hiting the truck under neath. Is this the universal joint going bad. Thank you
Tuesday, January 6th, 2009 AT 10:29 AM
RHALL77
  • 3,361 POSTS
Check the spark on those 2 cylinders and see what you have. You may also have a bad head gasket leaking antifreeze in the cylinders. As for the noise its hard to tell whats causing that with out hearing it
Tuesday, January 6th, 2009 AT 6:45 PM
