Could use more info.
Are you getting a "clicking" Noise?
Battery not charged or charging
Replace/charge battery
Replace alternator
Ignition switch has short or a broken wire
Replace wiring harness/assy
Check fuses replace if needed
Does the engine turn over but not start
Ignition coil
Replace the ignition coil
Replace the cap, rotor and spark plug wires
Engine doesn't turn over AND "whirring or very fast "zipping" sound?
Starter motor
Replace the starter motor
No sounds at all?
Check for shorts in all wiring to/from the ignition
switch, alternator, starter motor, ignition coil.
Wednesday, November 26th, 2008 AT 10:41 PM
