1992 Chevy S-10
DEBORAH6867
  • 1992 CHEVROLET S-10
Engine Mechanical problem
1992 Chevy S-10 6 cyl Two Wheel Drive Manual
it won't start it is getting fuel to the engine but won't catch to start what could it be and how do I fix it
Wednesday, March 24th, 2010 AT 5:31 PM
Do below and comeback with some results>
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Wednesday, March 24th, 2010 AT 6:09 PM
