1991 Chevy S-10 new clutch Master installed
RITCHIEDFW
  • 1991 CHEVROLET S-10
  • 6 CYL
  • MANUAL
  • 13,800 MILES
Where is the bleed valve and how do I get to it?
Monday, February 23rd, 2009 AT 5:44 PM
JMZHBZ
Raise drivers side of vehicle. Preferably on ramps. Follow line from the clutch master cylinder to tranny. Where the line goes into the slave cylinder, right above it, is a 12mm bleeder screw. It is easiest if you take the line loose out of the slave cylinder, insert it in a jar of fluid and pump a couple of times. You will notice a lot of bubbles. While doing this make sure the master cylinder does not empty itself. After you see no more bubbles in jar after pumping reconnect to slave cylinder and bleed it the same as you would brakes.
Sunday, March 1st, 2009 AT 6:49 PM
