1991 Chevy S-10 clutch master cyclinder
250,158 MILES • 6 CYL • 2WD • MANUAL
HARLEY80
clutch master cyclinder how hard to take off & replace
Jun 9, 2010 at 1:08 PM
BLUELIGHTNIN6
  • 16,542 POSTS
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_2327.jpg
Jun 9, 2010 at 1:54 PM
HARLEY80
put in new clutch pressure plate flywheel bleed the the slave drive ,but no pedal clutch master slave is bad do the bolts are under neath steering wheel is that where there at to take off clutch master slave it has two tie downs on it i,m a handycap person trying to get clutch to work is where you take off clutch master slave thanks i,m been working on it now for three days.thank you for replying
Jun 9, 2010 at 2:46 PM
