at approx. 35mph i feel a wooble in the front end, but not much shake in the steering wheel. i jacked up the pas. side and found that i could shake the wheel horizontly about 1/2 inch. i then checked the driver side, and found the same. i can see the tie rod moving, but fail to see any free movment in its joints. with the truck on the ground, i watched the tie rod movment as the steering wheel was being turned back and forth, the only free joint movment that i saw was very minor in the tie rod joint that connects to the steering box arm. at one time i felt this same wooble, but at a speed over 60. when it started at the slower speed, it seemed to get worse each time i drove it. i live in buffalo, ny. its cold, i dont have a grage, and my wife is on me to get it fixed, so she can have her car back. what do you think, what should i look for?
Jan 28, 2008 at 4:26 AM
