A couple of things, when bleeding make sure the master clutch cylinder is full. Start the truck up for a second with it in neutral, The clutch fork could be hanging up a little. Then try again to bleed the cluch slave cylinder. Important don't let the new cylinders go dry. Did you bleed the clutch cylinder first then the slave cylinder.
SPONSORED LINKS
Thursday, January 31st, 2008 AT 10:36 AM
