Put in new clutch master cylinder, now can't get to bleed. No fluid in line past master cylinder, dry at slave cylinder?
Friday, July 9th, 2010 AT 1:49 PM
HMAC300
MECHANIC
This probably should be power bled, but what you can try is to take the bleeder right out of the slave and let it gravity bleed that way. AFter you let it do that for a little bit, put the bleeder back in and try to bleed it by pumping it up. If that doesn't work you'll have to power bleed it.
