1991 Chevy S-10
MATT4401
  • 1991 CHEVROLET S-10
Electrical problem
1991 Chevy S-10 4 cyl Manual
What do the 2 small wires on the top of the alternator on a 91 chevy s10 with a 2.5L 4cylinder do?
Monday, December 29th, 2008 AT 7:09 PM
JMICHAEL8888
  • 45 POSTS
If they are black they are ground, other wise I know at least one of them (brown I believe) signals the battery lamp on your dash. Big red of course goes to battery.
Monday, December 29th, 2008 AT 8:20 PM
MATT4401
  • 12 POSTS
One is pink with a black stripe and one is brown. I know the big red wire goes to the battery, but I was wondering if the brown and pink have anything to do with charging? Also how do I check if the alternator is charging?
Monday, December 29th, 2008 AT 8:45 PM
JMICHAEL8888
  • 45 POSTS
Yeah that brown wire goes to the battery light, the other im not sure but im sure it doesnt have anything to do with charging. If you have a volt meter, check battery for volts, engine off. It should be about 12.5 volts.
With the engine running a good alternator will put out about 14.5 volts (checked at the battery). If you have a lot of accesories turn everything on(heavy load) and note the voltage.
Monday, December 29th, 2008 AT 8:54 PM
MATT4401
  • 12 POSTS
Hey thanks alot. You`ve been alot of help.
Monday, December 29th, 2008 AT 8:59 PM
