1987 Chevy S-10 trouble starting vehicle after it warms up
160,000 MILES • 6 CYL • 2WD • AUTOMATIC
PATRIOTSINGER
I have a 1987 Chevy S-10 with 160k miles on the 2.8 engine. I'm having a problem with it as follows:
It starts and runs o.k., but when the engine has warmed up and I try to restart it after a few miinutes, it will not crank. I replaced the fuel filter, but that didn't solve the problem. When I was changing it, I noted that it was getting fuel to the filter and had plenty between the filter and throttle body. I can hear the fuel pump working as well. Can you advise what the problem might be? Thanks, Keith
Jul 11, 2008 at 9:29 AM
  • 75,988 POSTS
it will not crank
Do you mean it cranks over but refuses start or just won't crank engine over
Check the fuel pressure and give me the readings this is where we start if its cranking over and refusing to start
Jul 11, 2008 at 9:59 AM
