1987 Chevy S-10 6 cyl Four Wheel Drive Manual
87 s10, 4x4 wont engage, this is what I have figured out so far. The 4wd actuator isnt getting a vacuum to lock the hubs, so I took a vacuum brake bleeder and hooked it to the actuator and the 4wd works perfect, but the 4h 4L indicator lights dont work, and never have. So where do I start? The switch for the console lights? Some sort of vac switch? Vac pump? Something else? Any help would be greatly appreciated. Thanks!
SPONSORED LINKS
Wednesday, February 10th, 2010 AT 4:04 PM
