1999 Chevy Astro Won't Start
CHEVROLET
SKILS93CAMARO
  • 7 POSTS
1999 CHEVY ASTRO VAN V6 2WD .......
WE WERE DRIVING AND ALL OF A SUDDEN THE VAN STOPPED.......WE FIGURED IT WOULD START RIGHT UP AGAIN BUT IT DIDNT......IT WOULD CRANK AND EVERYTHING BUT IT WOULDNT START...IM NOT SURE IF ITS THE GAS PUMP OR WHAT.......ANY HELP WOULD BE APPRECIATED
THANKS
Jan 9, 2007 at 7:46 AM
BOOTDOG
  • 665 POSTS
turn the key to the on position and see if you hear the fuel pump run for a few seconds. it'll be a high pitch whine. if not take a hammer and tap on the bottom of the gas tank while someone else tries to crank over the vehicle. if it starts replace the fuel pump. if it doesn't then check to see if you have power going to the fuel pump. you might even have a bad fuel pump relay. if the fuel issue is good then you'll need to check for spark. check for fuel first and let me know. if you don't hear a respone tonight i'll will respond tomorrow. good luck
Jan 9, 2007 at 11:15 AM
Suggested Repair
With the key on, listen for a brief high-pitched fuel-pump whine. If it is absent, tap the bottom of the tank while cranking; if that starts the van, replace the fuel pump. If not, check power at the pump and the fuel-pump relay. If fuel delivery is good, check for spark.
Conversation Summary
A 1999 Chevrolet Astro V6 2WD stopped while driving and then cranked but would not start. The owner suspected the fuel pump. The expert advised listening for the pump to prime with the key on, tapping the tank while cranking, and replacing the pump if that starts it. If not, check pump power and the relay, then check spark if fuel delivery is good.
