1991 Chevrolet Astro Cranks No Start
JINDANOTT
astro cranks but will not start. replaced fuel pump, crank sensor, and fuel pump relay. What could it be
Sep 4, 2007 at 3:13 PM
POET042005
  • 134 POSTS
The next step would be to check for spark.
Their are three things that fires it up 1:gas 2:spark 3:compression.
there are different ways to check for spark, heres one way.
pull a spark plug wire and take a screw-driver and place the metal part into the plug then take it and place it near bare metal on the fram or engine, but don't sit the wire and driver on the metal. Next while you watch the plug have someone turn the car over watch for a blue spark from the frame to the driver. If you don't see it then theres no spark at the distributer.
You must then check the the coild pack and next the ecm (electronic control modual)
Sep 6, 2007 at 3:33 AM
Suggested Repair
Check for spark at a plug wire while cranking. If there is no spark, inspect the coil pack and then the ECM.
Conversation Summary
The owner of a 1991 Chevrolet Astro says it cranks but will not start after replacing the fuel pump, crank sensor, and fuel pump relay. The expert says fuel, spark, and compression are required and recommends checking for spark, then inspecting the coil pack and ECM if spark is absent.
