1992 Chevy Astro fuel pump/relay
CASIMERHINTZ
  • 1992 CHEVROLET ASTRO
  • 6 CYL
  • 4WD
  • 180,000 MILES
Hi, my van would not restart after long drive, cranks but no fuel pump noise, diconnected battery[tip I was told ] waited 30 min then rehooked then it started, 2 days later happened again so tried proceedure that seemed to work but nothing, after an hour it started again, I was told it was relay, last summer I had crankshaft sensor give me similar problem, any idea?Thanks, casimer
Thursday, June 19th, 2008 AT 3:35 PM
When it refuses to start-you need to check for fuel and spark then comeback and tell us what's missing-
Could be CPS problem again-if the computer don't see the CPS signal it will not tell the ignition control module to fire the coil.
Thursday, June 19th, 2008 AT 4:06 PM
