1997 Chevy Astro FUEL PUMP
1997 CHEVROLET ASTRO
127,000 MILES • 6 CYL • 2WD • AUTOMATIC
DARRELLC.M.
R&R FUEL PUMP, STARTED AND RAN FOR A SHORT TIME AND THEN STOPED, SO I REPLACEDFUEL PUMP RELAY,FUEL FILTER,IGN.RELAY, I CAN TAP ON FUSE,RELAY PANEL UNDER HOOD AND WILL CRANK &RUN AGAIN CAN YOU HELP SIGNED , BUMM FUZZELD
Jul 12, 2009 at 7:02 AM
BUDDYCRAIGG
  • 2,262 POSTS
I run across a common problem on GM trucks.
The female connectors in the fuse box that the fuel pump relay plugs into. They loose their "springiness" from getting hot, and dont have a good grip on the relay anymore.
Jul 12, 2009 at 7:35 AM
