1999 Chevrolet Tahoe Rear U-Joint Cost
CHEVROLET
BLAZERRF88
was wondering if anyone could give me an estimate on the cost of having a rear u-joint replaced on a 1999 chev tahoe 4x4. thanks
Jul 11, 2006 at 1:51 PM
VANDRAGON
  • 298 POSTS
u joints don't cost much. if they are still set in with nylon like the older models, they have to be heated to be removed from the driveshaft. if you have not done it before it can be very dangerous. just shop around. even go to autozone and ask if they know an independant mech. most shops will charge 65 to 100 an hour for a simple job.....good luck
Jul 12, 2006 at 1:46 PM
Suggested Repair
Have a shop replace the rear U-joint rather than doing it yourself if you are inexperienced. Parts are inexpensive; labor is commonly about $65 to $100 per hour. Nylon-retained joints may need heat to remove them from the driveshaft, which can be dangerous. Shop around, and a parts store may know an independent mechanic.
Conversation Summary
The owner asked for a cost estimate to replace a rear U-joint on a 1999 Chevrolet Tahoe 4x4. The expert said U-joints are inexpensive, nylon-set joints may require heat to remove and can be dangerous for someone who has not done the job, and most shops charge about $65 to $100 an hour. They recommended shopping around, including asking a parts store for an independent mechanic.
