was wondering if anyone could give me an estimate on the cost of having a rear u-joint replaced on a 1999 chev tahoe 4x4. thanks
Jul 11, 2006 at 1:51 PM
Have a shop replace the rear U-joint rather than doing it yourself if you are inexperienced. Parts are inexpensive; labor is commonly about $65 to $100 per hour. Nylon-retained joints may need heat to remove them from the driveshaft, which can be dangerous. Shop around, and a parts store may know an independent mechanic.
The owner asked for a cost estimate to replace a rear U-joint on a 1999 Chevrolet Tahoe 4x4. The expert said U-joints are inexpensive, nylon-set joints may require heat to remove and can be dangerous for someone who has not done the job, and most shops charge about $65 to $100 an hour. They recommended shopping around, including asking a parts store for an independent mechanic.
