2002 Chevrolet Cavalier Fast Left Blink
CHEVROLET
RWALTHER
Hello, I have a 2002 Cavalier with 81,000 miles. My question is, Whenever I use the left turn signal it has an accelerated blink unlike the right turn signal. The right turn signal works fine, but not the left one. I have checked the fuse and it seems to be fine. I can't think of what else to check, any help would be greatly appreciated.
Dec 14, 2006 at 7:06 AM
CARUNDELL
  • 602 POSTS
[quote:f86a48327e="rwalther"]Hello, I have a 2002 Cavalier with 81,000 miles. My question is, Whenever I use the left turn signal it has an accelerated blink unlike the right turn signal. The right turn signal works fine, but not the left one. I have checked the fuse and it seems to be fine. I can't think of what else to check, any help would be greatly appreciated.[/quote:f86a48327e]
Hey rwalther,
That usually indicates a bulb is out, check the side that is not working, you should see either front or rear inoperative. check the bulb on the one not working!
Chris
Dec 14, 2006 at 7:16 AM
Suggested Repair
Inspect the left-side turn signal bulbs, front and rear, and replace any bulb that is burned out or not working.
Conversation Summary
The owner of a 2002 Chevrolet Cavalier reports that the left turn signal blinks faster than the right, while the right signal works normally. The fuse was already checked and appeared fine. The expert says a fast blink usually means a bulb is out and recommends checking the left front and rear bulbs for an inoperative lamp.
