1988 Chevrolet Cavalier Cold Shift Issue
CHEVROLET
DENNIS MURRAY
i have a 1988 cavalier with a 2.8 motor and a 5 speed tranny with 134,000 kl. the problem is the shifter won`t move side to side to shift gears unless i warm up the car for 1/2 hour.i changed the fluid to synthetic oil and oiled the linkage and it never made any difference.the weather here is minus 20. is there any other things i could check
thank you
Dec 5, 2006 at 2:01 PM
CARUNDELL
  • 602 POSTS
[quote:2c08aec1a3="dennis murray"]i have a 1988 cavalier with a 2.8 motor and a 5 speed tranny with 134,000 kl. the problem is the shifter won`t move side to side to shift gears unless i warm up the car for 1/2 hour.i changed the fluid to synthetic oil and oiled the linkage and it never made any difference.the weather here is minus 20. is there any other things i could check
thank you[/quote:2c08aec1a3]
Hey dennis,
You may end up having to also check/lube the linkage at the shifter itself (center console) those older models where not protected from the elements that well! Hope this helps!
Chris
Dec 6, 2006 at 6:15 AM
Suggested Repair
Check and lubricate the shift linkage at the shifter in the center console. On these older models it is poorly protected from the elements and can bind in extreme cold.
Conversation Summary
The owner of a 1988 Chevrolet Cavalier with a 2.8 engine and five-speed transmission says the shifter will not move side to side until the car warms for about half an hour in minus-20 weather. Changing to synthetic fluid and oiling the linkage made no difference. The expert suggests also checking and lubricating the linkage at the shifter in the center console, noting older models were not well protected from the elements.
