1999 Chevy Astro Intermittent No-Start
CHEVROLET
MCCORMACKLA
I have a 1999 Chevy Astro van 150,000 miles. I have been having trouble for the past few months. Most of the time it starts just fine, but once in a while it won't start. It turns over normally, but acts like it's getting no gas. Then a few minutes or sometimes hours later it will start right up. Any ideas please?
Jan 7, 2007 at 12:34 AM
SERVICE WRITER
  • 9,123 POSTS
The key to solving this riddle is to do testing when the problem is happening.
When it happens, take off the air snorkel to access the throttle body and manually open the throttle plate, spray some starting fluid into it and then crank it. Does it start for a moment. If it does, your right about lack of fuel, if it doesn't your going to chase down a lack of spark problem.
Post back after that point. Inquiring minds want to know :wink:
Jan 7, 2007 at 12:41 AM
Suggested Repair
When the no-start occurs, remove the air snorkel, open the throttle plate, spray starting fluid, and crank. If it fires briefly, investigate fuel delivery; if it does not, check for spark.
Conversation Summary
A 1999 Chevy Astro with 150,000 miles usually starts normally but sometimes cranks without starting, as if it is getting no fuel, then starts later. The expert advised testing during the failure by spraying starting fluid into the throttle body to distinguish a fuel problem from a spark problem, then reporting the result.
