1994 Chevy S10 Won't Start After Sitting
CHEVROLET
JOEK
I have a 94 chevy S10 6 cyl. 140k miles. if it sets a day , wont start unless jumped. replaced the battery and had the alt checked ok. any ideas thanks
Aug 4, 2006 at 9:25 AM
SYNCRAIT
  • 235 POSTS
my guess is that you have a slight drain on the battery or you have a bad cell in the battery itself.... try taking the + off the battery and hook up a test light from the battery terminal to the cable. if the light lights up then you have a small drain.... you might want to bring your battery in and have it tested for free at most any major auto part stores or look for mabe a light that is staying on ie... in the glove box possibly even the light to illuminate the cigarette outlet good luck :)
Aug 8, 2006 at 5:31 AM
Suggested Repair
Check for a parasitic battery drain with a test light between the positive battery post and cable, have the battery load-tested, and look for a light left on such as the glove box or cigarette lighter lamp.
Conversation Summary
The owner of a 1994 Chevy S10 says it will not start after sitting a day unless jumped, even after replacing the battery and confirming the alternator is good. The expert suggests a small battery drain or a bad battery cell, a test-light drain check, a free battery test, and checking for a light that stays on.
