2000 Chevy S-10 No Power When Starting
2010 CHEVROLET
JAIMEADRIAN
I have a 2000 chevy s-10 pickup, 6 cylinders, a week ago I started having trouble turning it on. At first it would want to start but then it would completely die as if it had not power at all. I had the battery checked and it is good. This morning it sounded like it wanted to start then all of a sudden it went completely dead as if the battery wasn't any good, what can it be?????
Thanks Patty :(
Aug 25, 2006 at 6:00 AM
MIKEYBDMAN
  • 623 POSTS
[quote:e024a2d913="jaimeadrian"]I have a 2000 chevy s-10 pickup, 6 cylinders, a week ago I started having trouble turning it on. At first it would want to start but then it would completely die as if it had not power at all. I had the battery checked and it is good. This morning it sounded like it wanted to start then all of a sudden it went completely dead as if the battery wasn't any good, what can it be?????
Thanks Patty :([/quote:e024a2d913]
check your battery cables for corrosion, or loosness. It can be at the battery, or the other end. Make sure you check your engine ground where the battery cable attaches to the engine block.
Aug 26, 2006 at 6:07 AM
Suggested Repair
Inspect the battery cables for corrosion or looseness at the battery and at the other ends, and check the engine ground where the battery cable attaches to the engine block.
Conversation Summary
The owner of a 2000 Chevrolet S-10 with a six-cylinder engine reports intermittent starting trouble that ends in a sudden total loss of power, even though the battery tested good. The expert recommends checking the battery cables for corrosion or looseness and inspecting the engine ground connection at the block.
