my rear window defogger has stopped working. Is this something that I can troubleshoot and repair myself? I have a 2001 chevy monte carlo ss
Dec 24, 2006 at 7:21 AM
Test the rear defogger fuses and relays with a test light or meter. If they are good, remove the dash switch and check for power in and out when it is switched on. If the switch is good, test continuity of the wire from the switch to the defroster unit.
The owner of a 2001 Chevrolet Monte Carlo SS asked whether a nonworking rear window defogger can be troubleshot and repaired at home. The expert recommended testing the fuses and relays with a test light or meter, then checking the dash switch for power in and out, and finally testing continuity of the wire from the switch to the defroster unit.
