1997 Chevy Suburban No Start
CHEVROLET
KAT774
I have 97 chevy suburban 4x4 k1500 with 95,000 miles on it. I have replaced my fuel pump, fuel filter, ECM, and fuses for the fuel system and Im still not getting the truck to start. can you help me narrow the problem down. I have also had my transmission replaced along with the drive shaft
Jan 24, 2007 at 4:09 AM
INDYUKE
  • 416 POSTS
Check fuel pressure at the fuel rail atop the engine, and check that each spark plug is getting spark.
Also check to see if the check engine light is on. If it is on, it indicates there is something awry with an emission related component.
Jan 24, 2007 at 1:19 PM
JEFTFIELDS
  • 74 POSTS
even though you dont say if you have spark or not, check the distibutor shaft for side movment, and also check modul in dist.
Jan 24, 2007 at 1:31 PM
Suggested Repair
Check fuel pressure at the fuel rail and confirm spark at each plug. Also check whether the check engine light is on, inspect the distributor shaft for side movement, and test the distributor module.
Conversation Summary
A 1997 Chevrolet Suburban K1500 4x4 with 95,000 miles will not start despite replacement of the fuel pump, fuel filter, ECM, fuel-system fuses, transmission, and driveshaft. Advice is to check fuel-rail pressure, spark at each plug, and the check engine light, then inspect the distributor shaft for side movement and check the distributor module.
