1998 Chevy K1500 Hesitation at Speed
CHEVROLET
MIGUELC
I have a 1998 Chevy k-1500 6-cyl 4x4 with 170000 miles and it hesitates while driving around 50-70mph. I have to let go of the accelarator for it to stop. I recently replaced the fuel pump and it just stoped working again what might the problem be?
Dec 20, 2006 at 11:54 AM
BOOTDOG
  • 665 POSTS
did you replace the fuel filter? a clogged fuel filter will make it hesitate on acceleration also. by the symptoms it sounds like the vehicle is starving for fuel. also if the fuel filter is clogged and you don't change it after replacing the fuel pump you can burn up the new fuel pump. ALWAYS change the fuel filter when you replace the fuel pump. let me know :)
Dec 20, 2006 at 12:13 PM
MIGUELC
I did replace the fuel filter. And the fuel pump relay any suggestions?
Dec 23, 2006 at 10:43 AM
SERVICE WRITER
  • 9,123 POSTS
IF this is a 5.3, check the fuel pressure regultor, they had a leaking problem.
What brand of fuel pump? I stay with Delcos on these. Too many problems with aftermarket pumps. Bad from day one. Check the fuel pressure with a gauge that runs from the port to a gauge. Duct tape the gauge to the bottom of the windshield and run it, observing for change in pressure when problem occurs. This should help eliminate the pump, filter.
Dec 23, 2006 at 1:14 PM
Suggested Repair
With the fuel filter and pump relay already replaced, check fuel pressure with a gauge while driving and watch for a drop when the hesitation occurs. Prefer a Delco pump if the pump must be replaced; aftermarket pumps are often unreliable. The leaking regulator note applies to 5.3 engines and may not fit this 6-cylinder.
Conversation Summary
A 1998 Chevy K1500 6-cylinder hesitates at about 50-70 mph until the accelerator is released. The fuel pump, fuel filter, and fuel pump relay were already replaced. Experts said a clogged filter can starve the engine and damage a new pump, and recommended monitoring fuel pressure during the symptom and using a Delco pump rather than an aftermarket unit.
